Linux version adds .jpg extension
KPAH
Post by KPAH »
I run the latest XNviewMP under linux with XFCE DE.
However, if you open a .jpg file in a browser, right-click and copy it, then paste to a new file in XNView and the save it, the file will get a second extension.
Also, if you select two files in XNview browser and create a joint image via XNview build-in tool, clicking save will produce a Strip 1.jpg.png file.
Re: Linux version adds .jpg extension
I've seen theses issues in Linux Mint Cinnamon 20 too...
Also an issue when renaming files in the XnView MP browser, when the filename becomes difficult to read after it is selected, do you see that too?
KPAH wrote: Tue Nov 16, 2021 6:28 pm However, if you open a .jpg file in a browser, right-click and copy it, then paste to a new file in XNView and the save it, the file will get a second extension.
you make a copy of a file in browser, ok, but after i don't understand what do you means?
KPAH
Post by KPAH »
this seems to have been fixed at some point
