RC5: Tip dialog: Next tip at startup
Locked
When starting XnView, the tip dialog appears (unless it has been deactivate). At startup, always the first tip is shown. Instead, the tip dialog should show a tip per startup, remember the last tip shown, and show another tip at next startup.
Note:
Not a real bug, but tip dialogs are supposed to work like described above.
Re: RC5: Tip dialog: Next tip at startup
helmut wrote:When starting XnView, the tip dialog appears (unless it has been deactivate). At startup, always the first tip is shown. Instead, the tip dialog should show a tip per startup, remember the last tip shown, and show another tip at next startup.
Note:
No, it's not really the first tip. I show always the "Use all formats " tip first, because i think it's very important. Try to enabled option/General/Use all formats
Note:
Even if the hint on special format is important, I don't like showing up the same tip all the time. Could you please make the "Special format" tip a normal tip - just like the others?
Dreamer
Post by Dreamer »
I agree with Helmut.
Verified fixed in RC6. Thank you Pierre!
Locked
