Text customization in Fullscreen & other
OnO
Post by OnO »
I found XnView great... much better than "the others" with nice looking GUI etc. etc.
However when I switch to the fullscreen viewing I found that there's no way to change the ugly SYSTEM font of image's filename.. or to turn off displaying it. Also hate that the text is not transparent but fixed with black background.
Well it would be nice to have in options:
[x] Display image's filename
[x] Transparent image's filename
Image title / filename font [ ... Font chooser ]
Align title [ Left | Center | Right ] / [ Top | Middle | Bottom ]
Or even some filename toggle key shortcut would be much apriopriated.
(When I just want to see nice pictures.. without the titles)
I found also a :bugconfirmed: (I think): when going out from full screen mode horizontal scrollbar disappears, even it should be there because of image size. Tested it ...
Last Wish (idea) is alternate shortcut set (Irfan way).. with no Ctrl+ and so on.. but simple keys like S for resize R for rotate... this would accelerate commonly used actions.
Best regards,
Adam
crazytb
Re: Text customization in Fullscreen image & other
Post by crazytb »
OnO wrote:I found also a :bugconfirmed: (I think): when going out from full screen mode horizontal scrollbar disappears, even it should be there because of image size. Tested it ...
If it is what I think, it has been fixed in newer releases. :bugfixed: What version are you using?
The idea of more options for image filename are good. So, I think that will be nice to have a shortcut inside full screen mode to toggle display of filename. So, I may watch a slide show of my wallpapers and, when I see a good one, I press a key to show its name.
OnO
Re: Wish: Fullscreen image filename text customization &
Post by OnO »
1.70 RC2. I think it's a different issue.
Ha I know... when leaving fullscreenmode.. somehow view window (if it's maximized) goes under the status bar, which now overlaps the horizontal scrollbar. I think it's just some "leaving fullscreen" function bug.
Regards,
OnO de la Cravovia
ckit
Post by ckit »
I can reproduce this bug under XnView v1.70 RC2
SylvaiNN
Post by SylvaiNN »
ckit wrote:I found also a (I think): when going out from full screen mode horizontal scrollbar disappears, even it should be there because of image size. Tested it ...
Yes I can reproduce this "bug" too...
Yes a :bugconfirmed:
Pierre
