Can you vsort on IPTC field data?
222fbj
Post by 222fbj »
I would like to select a group of images based on IPTC field data.
Is there any way to use the View>Sort By feature(or another XNview feature) to sort by an IPTC field?
For example, the IPTC Date Field, or an IPTC category?
thanks
Re: Can you vsort on IPTC field data?
222fbj wrote:I would like to select a group of images based on IPTC field data.
thanks
Ok, but currently not possible... Perhaps a good feature...
