Hello XNView team,
I wanted to ask you when will you update all the libraries, including libheif to the last version? The new versions have new features and bug fixes.
I wish you the best,
Andrei Miloiu
Update all the libraries, including libheif to the last version
Re: Update all the libraries, including libheif to the last version
I noticed you updated libheif in XNView MP 1.9.0. Thank you! Until the next library versions the issue is fixed.
Andrei Miloiu
Andrei Miloiu
