1.88 Typo in Registry Setting
jbusnengo
Post by jbusnengo »
Double-clicking on a .sld file does not open XnView. Upon investigation, I discovered that there's a typo in the registry setting that needs to be fixed.
XnView creates the registry entry Computer\HKEY_CLASSES_ROOT\XnViewMP.sld\shell\open\command\(default) with the following string:
"C:\Program Files\XnViewMP\xnviewmp.exe" "-slide "%1"
Because of a missing quotation mark, this does not work. Correcting the string to this:
"C:\Program Files\XnViewMP\xnviewmp.exe" "-slide" "%1"
fixes the problem.
Re: 1.88 Typo in Registry Setting
yep, but it's not a quote mark, it's a space in the wrong place
current 188
[HKEY_CLASSES_ROOT\XnViewMP.sld\shell\open\command]
@="\"D:\\PROG\\portable\\graphic\\XnViewMP\\xnviewmp.exe\" \"-slide \"\"%1\""
fixed
@="\"D:\\PROG\\portable\\graphic\\XnViewMP\\xnviewmp.exe\" \"-slide\" \"%1\""
jbusnengo
Post by jbusnengo »
Thanks!
This problem is supposed to be fixed in XnView MP 1.9.0. Please check and confirm the bug fix here.
fixed in 190
jbusnengo
Post by jbusnengo »
I'm still having the same issue. Each time I update XnView MP, the registry setting gets reset to include the typo. It happened with 1.9.0 and 1.9.1. Do I need to completely remove XnView MP and reinstall fresh rather than updating my existing installation? Thanks!
jbusnengo wrote: Wed Jun 04, 2025 1:28 pm Each time I update XnView MP, the registry setting gets reset to include the typo.
yeah, looks like issue is not fixed in installer
jbusnengo wrote: Wed Jun 04, 2025 1:28 pm Do I need to completely remove XnView MP and reinstall fresh rather than updating my existing installation?
press 'Set file associations...' button in Settings > Integration
jbusnengo
Post by jbusnengo »
user0 wrote: Wed Jun 04, 2025 1:45 pm
Ah. I wasn't aware of that button. That does appear to work.
