ICC profile problem [SOLVED]
Pizzacutter
Post by Pizzacutter »
I've got a problem using an ICC profile made using DisplayCAL for my Asus ProArt 24" monitor -- XNView MP can't use it. It is recognized and utilized by Darktable, apparently by browsers like Vivaldi and Firefox as well... but not XNView MP.
This is what I see with the display profile enabled in the Color Management settings (it's one of the ICC test images):
Any other profile works though... I have a few older profiles for the same monitor and they work too.
Important thing to note: I actually have no idea if XNView MP has anything to do with this, maybe it's a DisplayCAL problem, but I don't know where to ask, I'm a bit desperate...
Please see attached zip file - the older one (2024-11-24) should work, but not the newer one (2025-04-17). If anyone could guide me where to look for the problem or what's wrong with the ICC profile I'd be really grateful.
Oh, and here are the test images:
https://displaycal.net/icc-color-management-test/
My specs:
- Windows 11 23H2
- Calibrite Display SL
- Asus ProArt PA248QV
profiles.zip
(1.67 MiB) Downloaded 134 times
Pizzacutter
Re: ICC profile problem
Update: This problem is not present on Ubuntu Studio install, so apparently it's Windows specific...
mudo_j
Post by mudo_j »
Renaming profile from ...125cdm²... to ...125cdm2... removes the problem.
Pizzacutter
Thank you so much! I couldn't figure out what was the problem... I noticed it started happening with all new profiles since the beginning of this year and I had no idea what could've changed :mrgreen:
