Configurable keyboard shortcuts needed for 'Fit image to desktop' and 'Fit window to image'
tajinoxn
Post by tajinoxn »
Would be great if customizable keyboard shortcut is added for 'Fit image to desktop' and 'Fit window to image', the other image fitting modes are already in configurable keyboard shortcuts, just missing these 2 fitting that I find myself using all the time.
Hope you can add these 2 to the configurable key list in the coming updates, thanks.
Re: Configurable keyboard shortcuts needed for 'Fit image to desktop' and 'Fit window to image'
they are already there
change Browser to Viewer in the combobox in the top left corner
tajinoxn
Post by tajinoxn »
What do you mean they are already there? I've looked through the mappable key list in Tools > Settings > Interface > shortcuts page, search for 'fit', there are no 'Fit image to desktop' and 'Fit window to image' command in the user mappable shortcut key list.
I know how to switch from Browser to Viewer. This feature request is about adding the 'Fit image to desktop' and 'Fit window to image' commnads to the user configurable keyboard shortcuts.
Just to clarify, the 'Fit image to desktop' and 'Fit window to image' commands is accesible in Viewer mode, top menu View > Zoom submenu. Currently those 2 commands are not accesible with user assigned keyboard shortcuts.
tajinoxn wrote: Fri Feb 14, 2025 5:56 am Tools > Settings > Interface > shortcuts
go there again and do what I told you
tajinoxn
Post by tajinoxn »
Found it, that "Browser/Viewer" combo dropdown in the Shortcuts page really got me. Thanks for pointing it out again.
