no .fit entry in system settings - format .....
linuxer7
Post by linuxer7 »
Hi guys,
I use XnView MP 1.8.3 under Ubuntu-Mate and would like to manage or view my astrophotos with it. Basically every format works except .fit.
I use the German language and under system settings - formats there is no .fit entry. Do I have to install a plugin or is this a bug in the software?
A little help would be very nice. :)
Many thanks.
Thomas
Re: no .fit entry in system settings - format .....
do you have enabled 'Settings>General>Show all graphic formats'?
linuxer7
Post by linuxer7 »
Ohm, yes now :D
And now it works fine.
Thank you very much.
