Add the command of "convert filetype"
sibojan
Post by sibojan »
As far as I know, the current way to convert a file type (e.g. bmp to jpg) in Xnview is to "save as" and "delete" the original file. Is it possible to add a command to allow this to be done in one step? The MS photos app sets a nice example as seen below. File converter function is embed in the command of "resize image"
Re: Add the command of "convert filetype"
1. when you click the Save button (in MS Photos), the 'Save As' dialog opens, offering to save a new file in a new format, so you have to delete the original manually anyway
2. there is absolutely no reason to have a 'save to file' button in the resize dialog
sibojan
Post by sibojan »
You are right, but can you do better than MS photos?
provide greater convenience by providing a command to combine this "save as" and "delete" function to one step?
