Why was be removed Decoder and Encoder FLIF
Xn User
Post by Xn User »
Hi )
Why in latest versions absent libflif.dll ? This not good , because losting feature for read and write this format ) I understand what FLIF later moved to JPEG XL , but still ,why this plugin removed ?
I about this https://www.mediafire.com/file/qtqlxbby ... f.dll/file
Re: Why was be removed Decoder and Encoder FLIF
now in Tools/Plugins
Xn User
Post by Xn User »
But I can not install plugins https://www.mediafire.com/file/6nnn4cc0 ... s.avi/file
Where I can download plugins manualy ?
windows 10?
Xn User
Post by Xn User »
No , I use Windows 7 x64 )
Xn User wrote: Fri Jan 24, 2025 12:27 pm No , I use Windows 7 x64 )
on Win 7, there is a problem with archive.dll, you can take the dll from 1.4 package
Xn User
Post by Xn User »
Thank you ) but not will it be easierinclude all plugins to XnViewMP ?
JiyaHana
Post by JiyaHana »
Hi, I am curious about the decision to remove FLIF support from XnView. Are there any plans to bring back full FLIF support as a plugin, or will JPEG XL fully replace it in the future?
Xn User
Post by Xn User »
I think what JPEG XL in future replacing more formats , only need optimize viewing speed) now I in easy stupor at speed and CPU load , still when I7-6950X load up to 50% or more , this not normal , JPEG XL need optimization ) I think , what this format if not possible optimize on CPU , need move to GPGPU for example CUDA / OpenCL or QuickSync )
FLIF is supported with Tools>Plugins, is no more in the standard package
Xn User
Post by Xn User »
xnview wrote: Fri Jan 24, 2025 3:02 pm FLIF is supported with Tools>Plugins, is no more in the standard package
But why ? By size distribution this not differ )
Also archive.dll you can make this :
[Files]
Source: "C:\Source\Program\Data\XP\file.dll*"; DestDir: "{app}\"; Flags: ignoreversion createallsubdirs recursesubdirs ; MinVersion: 0,5.01.2600; OnlyBelowVersion: 0,6.0.6000
Source: "C:\Source\Program\Data\7\file.dll*"; DestDir: "{app}\"; Flags: ignoreversion createallsubdirs recursesubdirs ; MinVersion: 0,6.0.6000
in example as do for XP and 7 , but nothing It does interfere make do also for 7 and 10
