1.8.3: Import and Sort - Move to subfolders date issue
Weygert
Post by Weygert »
XnView: MP 1.8.3 - 64 bit
OS: Windows 64bit
I am usually importing my images to a separate folder with subfolders for each year/day.
In the past this worked fine (results as shown in Image1). I can't say with with version that worked, it's quite some time ago (suppose +6 months).
Today I noticed that all images were moved to one single folder with today's date (Image2).
1. Open Import and sort ...
2. I selected the source and kept all settings as in the past (Image3). Subfolders is activated, pattern is: [Y/Y-m-d]
3. Pressing OK renames the files properly and moves them into a new folder: ...\2025\2025-01-08.
Actual behaviour (bug): Images were moved to one single folder with today's date
Expected behaviour: Images should be moved to multiple folders with Year\Date per the image's EXIF data.
Maybe it's not technically a bug, but I'm sure it worked
Thanks for looking into this.
Screenshot 2025-01-08 200815.png (1.3 KiB) Viewed 868 times
Screenshot 2025-01-08 200615.png (2.27 KiB) Viewed 868 times
Re: 1.8.3: Import and Sort - Move to subfolders date issue
it works good here, could make an image set to reproduce?
