1.8.3: Tag or rating disappears when moving a file to a different drive
aucora
Post by aucora »
XnView: MP 1.8.3 - 64 bit
OS: Windows -64 bit
Effect:
Tag or Rating disappears when moving a file to a different drive
1. set a tag or rating on a file.
2. Move it to another drive, such as from drive C to drive D.
3. Its tag or rating will then disappear.
If you move it back to the original drive then the tag or rating comes back.
Hopefully this discovery will help in fixing the bug.
Thanks.
Re: 1.8.3: Tag or rating disappears when moving a file to a different drive
If you move on different folder on same drive, no problem?
What do you have in Settings>Metadata?
aucora
Post by aucora »
Thank you for mentioning metadata settings.
The issue has now been resolved and it is not a bug.
