Drag and drop to folders pane causes freeze Linux Fedora 41
Kenny Dave
Post by Kenny Dave »
XnView: MP 1.8.3 64-bit (Linux) - Libformat 7.196
OS: Linux Fedora 41 64bit
As per subject
Effect: Freeze. Program is unresponsive. Reopening shows that the file has been copied, it's doing what it should but then waiting for something that never happens.
1. Open XNViewMP
2. Drag an image file from the main window to the folder pane and drop
Re: Drag and drop to folders pane causes freeze Linux Fedora 41
no problem here on debian or ubuntu...
Kenny Dave
xnview wrote: Tue Nov 19, 2024 12:04 pm no problem here on debian or ubuntu...
Yes it didn't do it when I was in Mint, or even when I put KDE on Mint. I'm using the flatpak version, as there doesn't seem to be an rpm or other way to get a system install, I used the deb file before.
It's also doing odd things when I try and open a file on a mounted non-system drive. I think this is because it's flatpak though, and it crashes when I do it in system drives also so I don't think is related. I've checked the appimage version and it crashes for that too, but non-system drives work ok.
Kenny Dave
Any solution to this? I've been using the windows version in a bottle but that's decided to be unstable now too, understandably.
The message before the freeze is
BLOB length 75
######ThumbLoaderThread :: forever : 26b6a000
 ** start condition wait
It's inconsistent, sometimes it will do it no problem. It is copying a file to a different folder, whether that's via the folders pane or within the thumbnail pane. It's the same with the flatpak or appimage version. There isn't an rpm version or in the dnf repos that I can see.
Kenny Dave wrote: Wed Jan 08, 2025 9:21 pm Any solution to this? I've been using the windows version in a bottle but that's decided to be unstable now too, understandably.
Do you have tried the tgz package?
Kenny Dave
The TGZ package natively crashes the same. Or do you mean in the bottle?
MOVE file : </mnt/Vids/Media 3/0Sortbox/738826.jpg> => </mnt/Vids/Media 3/Pics/>
CheckContent...
ThumbLoaderThread :: stop()
## Check folder
  ## Check companion  0
  ## Check companion ok  0
SORT the list...
STD::SORT... 0
  STL::SORT... 3
SORT the list... 3
SORT the list... 3
###  checkChanged : 48
######### CategoryModel :: checkAndSave()
BitmapLoadThread :: stop()
@@ BitmapResizeThread:: clear
### ThumbLoaderThread :: setFileList(806)
 ** start condition wake one 2
######ThumbLoaderThread :: forever 2 : 30b3be70
CHECK <16>
### START 806
######ThumbLoaderThread :: start : 16     -1 -1
######ThumbLoaderThread :: forever : 30b3be70
i've tried on a clean install of fedora 41, and no problem. Do you use a X11 or wayland session?
E4474
Post by E4474 »
Same freezing problem with XNViewMP as a Flatpak using Fedora 41 Wayland with KDE interface. So far I have only tried to drag a file via thumbnail view to another folder in the left side folder tree. When XNView MP is reopened, the file shows in the new folder. So the file gets moved but XNView MP freezes and needs to be terminated, waiting does nothing.
Also I tried the downloaded AppImage and cannot get it to run. Nothing happens.
New to Linux and I have tweaked some of the OS settings vs using all defaults (I hate bloatware and installed unneeded files, so I play to learn to get rid of garbage such as language files I'll never use, unused bloated fonts, 3D crap and so on), so I admit that the problem could be on my system, but why oh why cannot programs offer users exactly what to install or not vs. myriad useless defaults? So I thought I'd add my XNViewMP freezing experience, as I looked for this in the forum and joined.
FWIW, XNView Classic would be my preferred program as I only need a fast viewer for culling and rating/flagging images as I use another program as a database manager. The other Linux offerings for fast simple small no database programs for FAST culling and rating of images don't really exist or the GUI is too Gnome / MacOS like to be usable. I would pay for such a fast small image culling and rating Linux program.
Kenny Dave
xnview wrote: Sat Jan 18, 2025 5:03 pm i've tried on a clean install of fedora 41, and no problem. Do you use a X11 or wayland session?
Wayland. It's KDE not Gnome. XNViewMP was fine when I put KDE on Mint, as far as I can remember.
Thanks for looking at it. It sounds like E4474 is KDE also if he's not keen on Gnome.
Kenny Dave wrote: Sat Jan 18, 2025 7:02 pm Wayland. It's KDE not Gnome. XNViewMP was fine when I put KDE on Mint, as far as I can remember.
i can reproduce, i'll check, perhaps a problem with latest KDE & Qt 5.15
Kenny Dave
xnview wrote: Wed Jan 22, 2025 4:52 pm I can reproduce, i'll check, perhaps a problem with latest KDE & Qt 5.15
That's great news, thanks so much.
Kenny Dave
Is there any news on this? Is it a problem with QT 5.15? Perhaps I can ask the relevant people to have a look if I know more about it.
I'm running XNViewMP in a VM at the moment which isn't ideal.
Kenny Dave wrote: Sat Apr 19, 2025 8:09 am Is there any news on this? Is it a problem with QT 5.15? Perhaps I can ask the relevant people to have a look if I know more about it.
yes it seems a problem with Qt 5.15
Kenny Dave
xnview wrote: Sat Apr 19, 2025 2:00 pm yes it seems a problem with Qt 5.15
Thanks.
Kenny Dave
Problem is still existing; is there a workaround perhaps? Could I change the session settings to X11 or something, a different source?
I'm on QTS 6.9, XNView MP 1.9.2 Libformat 7.226
Any moving of files causes a freeze.
Fedora 42,
KDE 6.3.5,
Wayland.
QT 6.9.
Kernel 6.14.9-300.fc42.x86_64 (64-bit).
Different XNView MP sources all seem to have the same issue.
