Error Navigating Inside CBR and CBZ Files
aticus
Post by aticus »
Hi master,
When you double-click on a .cbr or .cbz file, XnView enters the archive as if it were a regular folder. However, when you press the back button, instead of returning to the folder where the file was located (the expected behavior, i.e., "exiting" the file), it goes to the previous folder.
For example:
1. I visit Folder 1.
2. I visit Folder 2.
3. I open a CBR file.
4. The contents of the CBR file are displayed.
5. I press back, and it takes me to Folder 1 instead of Folder 2.
(I mistakenly posted this post in the wrong forum previously)
Re: Error Navigating Inside CBR and CBZ Files
