Find similar files - result - few improvements
XnViewMP 1.8.2 64bit
Windows11 (24H2), display resolution 3840x2160, win scaling 150%
  • few improvements
    • preview
      RAW and JPG results looks different (no issue with thumbnails)
      raw test files, resave as jpg
    • buttons
      - make button background/border transparent
    • folder
      - probably it would be better for long path to show first and last parts with truncation (..) in the middle
      eg like in Resize > Presets combobox
    • size
      - add space between numbers and abbreviations
    • type
      - camera model is shown instead of file type for raw files (nef, cr2, etc)
    • sort
      - there should be some default sort order, and it should be selected
    • highlight diffs
      in the details of image on the right
      eg via bold: blackbird.jpg blackbird.nef
