MP 1.8.1 export dialog - JPEGLI subsampling settings - 4:2:0 and 4:2:2 are swapped!
masterjp
Post by masterjp »
I did some tests with the new export dialog and JPEGLI settings.
I saved one picture with different sub sampling settings (4:4:4, 4:2:2 and 4:2:0).
Here are the results of the filesizes. It shows, that the sub sampling 4:2:0 produce bigger filesize than 4:2:2.
It is absolutely unusual, because 4:2:0 uses a higher compression and it produces a smaller filesize!
Then I further checked the EXIF-data of all saved jpeg files.
The EXIF informations show, that sub sampling setting 4:2:2 delivers a jpegli sub sampling of 4:2:0!
The jpegli sub sampling of 4:2:0 saves the file with 4:2:2!
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
Re: MP 1.8.1 export dialog - JPEGLI subsampling settings - 4:2:0 and 4:2:2 are swapped!
This problem is supposed to be fixed in XnView MP 1.8.2. Please check and confirm the bug fix here.
Kadet
Post by Kadet »
For me all is OK now (in Export and in Save As function).
