1.8.0 Loss of gamma correction when zooming beyond 100%
Vick
Post by Vick »
XnView: MP 1.8.0 - 64 bit
OS: Windows 10/64bit
The current image opened in the viewer loses the “Use gamma correction” (enabled in preferences) when zoomed beyond 100%, and the “High zoom quality” option is enabled.
Does not occur if “High Zoom Quality” is disabled, and if zoom is 100% or less.
Effect: The image loses gamma correction.
1. Enable “Use gamma correction” in preferences and set a value other than 1.00 (to see the effect)
2. Activate “High quality zoom”.
3. Open any image in the viewer, zoom to over 100%.
Current behavior (bug): :bug: Image loses gamma correction at zooms above 100% as if gamma correction is off or set to 1.00.
Expected behavior: keep gamma correction at any zoom level.
Re: 1.8.0 Loss of gamma correction when zooming beyond 100%
i'm not able to reproduce, which 'high zoom quality' do you use?
Vick
Post by Vick »
in the settings: (I'm setting the gamma to a very high value to see the effect in this example)
In menu View:
At Zoom 100% or less, the gamma correction is working:
More than 100% of zoom, the gamma correction is gone, no matter if windowed or full screen:
i reproduce when using 'bicubic'
Vick
Post by Vick »
xnview wrote: Mon Oct 14, 2024 11:52 am i reproduce when using 'bicubic'
Yes I did not see it before, but only "none" and "bilinear" works good on both zoom in and zoom out.
If I set any zoom to:
Bicubic
spline 16
spline 36
lanczos 3
lanczoz 4
the gamma correction is lost on both zoom in and zoom out when different from 100%
are you able to reproduce with 1.8.8?
