1.8.0 - compare - A/B mode - does not use bg, transparency settings
XnViewMP 1.8.0 64bit
Compare
A/B mode does not utilize the following settings (set in Settings > View):
a) custom [Viewer] Background color
b) custom Checkboard pattern
no issue in Normal and Tabs modes
Re: 1.8.0 - compare - A/B mode - does not use bg, transparency settings
Checkboard pattern is used but not bg color
I've added some details
fixed in 181
