Histogram disappear after I open settings window
digarw
Post by digarw »
I encountered a weird bug with histogram display. If I opened settings window (even without changing setting) and close it, it will disappear and just have blank display. It will stay like that after relaunch the app. It can be repaired by doing clean install by delete previous app data, but it can be disappear again by opening settings window.
Fix this please. I'm using windows 10 Pro with Intel integrated graphic for the info.
Re: Histogram disappear after I open settings window
if you click on a file, it reappears?
digarw
Post by digarw »
It doesn't. Even after I resize the side panel or detach it into single floating panel.
you need to restart XnView?
digarw
Post by digarw »
It doesn't work after restart. Like I said earlier, I already do clean reinstall by deleting previous app data folder and redownload the program several times. It does appear at first, but upon I try to open Settings window in Tools menu it will disappear. Not sure if this graphical bug or something else.
please send me your xnview.ini when you have this problem?
digarw
Post by digarw »
https://www.dropbox.com/scl/fi/yiasd96i ... 0f05o&dl=0
Just note that I didn't change much on setting. This bug occurred only when I clicked settings for first time.
you need to show preview to be able to show histogram
digarw
Post by digarw »
Huh? It works... So histogram need preview panel to be working. I kinda wish it doesn't need to.
Anyway, thanks for your great help!
