Full screen mode bug - v1.7.2
FKCapitalism2
Post by FKCapitalism2 »
I am not sure what is going on, but basically on Windows 10 i have used for short time feature Taskbar settings > Automatically hide the taskbar in desktop mode.
After launching XnViewMp with taskbar hidden i XnViewMP window have no upper right buttons minimize, maximize, close.
After i turned off Automatically hide the taskbar in desktop mode still XnViewMp shows above the taskbar hiding it entirely and i can't resize window without above mentioned buttons.
This screenshot with taskbar on in windows 10 settings, but it shows over it and no close buttons present in the window.
Re: Full screen mode bug - v1.7.2
it seems that you have disabled 'View>Title bar'
FKCapitalism2
xnview wrote: Sat Aug 31, 2024 7:18 am it seems that you have disabled 'View>Title bar'
Right, that fixed the issue, however is it intended that with disabled title bar XnViewMP window shows full screen and above the Microsoft Windows status bar on the bottom?
