RC1: Parent folder ".." is always on (only my ini)
Locked
ckv
Post by ckv »
As the subject says the parent folder ".." is always on regardless of the options. This doesn't occur with clean ini t and my ini is created by RC1, so this isn't ini incompatibility bug.
Get my ini: [EDIT]
Xyzzy
Post by Xyzzy »
Here parent folder [..] is not displayed with your ini in thumbnails view.
XP SP2
X.
Dreamer
Post by Dreamer »
Xyzzy wrote:Here parent folder [..] is not displayed with your ini in thumbnails view.
XP SP2
X.
Strange, I can confirm this bug. Could you try again please?
I had similar bug, we should test this option more (items displayed).
Xyzzy
Post by Xyzzy »
Strange, now I get it too. Maybe I did something wrong at the first time.
Confirmed.
X.
Re: RC1: Parent folder ".." is always on (only my
ckv wrote:As the subject says the parent folder ".." is always on regardless of the options. This doesn't occur with clean ini t and my ini is created by RC1, so this isn't ini incompatibility bug.
Get my ini: xnview.ini
Yes, it's normal, you have filter on 'All' and not 'Custom'
Dreamer
Post by Dreamer »
So no bug? But it could be confusing, there should be at least some note in Options about this 'conflict' with filter option.
(Moved to New/Open)
(Moved to New/Open)
It's not a conflitc but a choice of the user. But how to show it?
Post by Guest »
xnview wrote:It's not a conflitc but a choice of the user. But how to show it?
Use different icon when filter other than Custom is applied.
Rename 'Items displayed' to 'Custom filter' in options.
X.
But items displayed was a requested change :-(
Post by Guest »
xnview wrote: But items displayed was a requested change :-(
So also add description (in next version) to Items displayed options page, something like 'Please choose... (Custom Filter)'. User should easier connect these features; and Close for now.
X.
ckv
Post by ckv »
Close please.
The bug I describe was normal behavior depending on used options. If you want to change this behavior, please make a new request for it.
Locked
