Browser - filelist - context menu - unify behavior
XnViewMP 1.7.1 64bit
Browser - filelist / navigation pane
Win File Explorer has functionality to invoke full/old context menu via SHIFT+RMB click.
However, XnViewMP uses different shortcut (CTRL+RMB click) in Browser, which is inconvenient.
  • unify behviour of system context menu invoking
    • click on file/folder in filelist / folder in navigation pane
      - use SHIFT+RMB instead CTRL+RMB
    • click on empty space in filelist
      - always show application context menu (CTRL+RMB shows nothing right now)
Related
Re: Browser - filelist - context menu - unify behavior
This problem is supposed to be fixed in XnView MP 1.8.0. Please check and confirm the bug fix here.
done in 180
