Post
by user0 »
XnViewMP 1.6.4 64bit
Settings - General
- auto-rotation.png (22.67 KiB) Viewed 978 times
- rename
Rotate images according to EXIF orientation tag →
Auto-rotate images according to EXIF orientation tag
as it rotates images automatically (in Browser/Viewer)
Example
- FastStone
Auto-rotate by EXIF orientation tag
- IrvanView
Auto-rotate image according to EXIF info (if available)
Post
by xnview »
Thanks to your detailed description I can reproduce
the problem.
Post
by xnview »
This problem is supposed to be fixed in
XnView MP 1.7.0. Please check and confirm the bug fix here.
Post
by user0 »
done in 170
