CMD >>> upload image
Mrakobes666
Post by Mrakobes666 »
How do I set up image upload using the command line to search for an image in Google images (similar)? You probably need to interact with the api or at least with the browser, if firebox supports CMD
Re: CMD >>> upload image
sorry but i don't understand
Mrakobes666
I often use Google to search for a similar image, this can be done with the right mouse button from the browser or by dragging the image into the browser window. I've been wanting to implement a function for a long time - in the viewer, you select an image and click on the panel button, the image is uploaded to the browser to search for a similar image. I came up with the idea that it might be possible to do this using commands and additional free console applications?
