Fit image to window when opening
XnXo
Post by XnXo »
Hi. Is it possible to set it so that when I double click an image and it opens for editing and viewing, it opens at a zoom level that fits the whole thing in the panel, rather than opening at full size?
I've looked for this setting but can't find anything.
Thank you! :)
Re: Fit image to window when opening
use 'Fit image to window'
XnXo
Post by XnXo »
Thank you. I'd been looking for something under under general settings, not in the window the image opens in. Found it! :D
