xmp.ini: "dc.subject_required=true" (keywords in XMP) Edit XMP (metadata) doesnt work as "requiered metadata"
Gerald_Ire
Post by Gerald_Ire »
XnView: MP 1.6.1 - /64 bit
OS: Windows 10 64bit
Empty "subject" (in "Edit XMP" / keywords) in XMP doesn show as "reuiered metadata" if marked "dc.subject_required=true" in xmp.ini
Effect: empty "subject" (keywords) in XMP does'nt show and work as "requiered metadata"
1. close XnViewMP ver. 1.6.1
2. edit "xmp.ini" and ad line "dc.subject_required=true" (making "subject" as reuiered...)
3. save xmp.ini and restart XnViewMP 1.6.1
4. Edit image with ...Metadta/Edit XMP...
5. there is no name under Keywords "subject" given over the metadata field...
5. there is no red asterix "*" shown at the metadata field...
6. when saving image with empty "subject" can be saved without warning "requiered..."
Actual behaviour (bug): "subject" has no name, no red asterix, saving without warning when empty :bug:
Expected behaviour: show name "subject", show red asterix when "requiered" in xmp.ini, show warning at saving when "subject" empty
______________________________________________________
Others, like iptc.ini and rest of xmp.ini works just fine! Well done!
:D Gerald says thx to all! :D
Re: xmp.ini: "dc.subject_required=true" (keywords in XMP) Edit XMP (metadata) doesnt work as "requiered metadata"
This problem is supposed to be fixed in XnView MP 1.6.2. Please check and confirm the bug fix here.
Gerald_Ire
Hi Pierre, sorry for the very late reply to this.
The iptc.ini works fine - as requested.
The xmp.ini doesnt work / see details:
The asterix is set at keyword (subject)
Took image sample from https://iptc.org/standards/photo-metada ... -standard/
The file contains already keywords - shown in GUI "xmp-edit"
Cant write without the error-window "keyword/subject missing"
Cant apply the error-window "keyword/subject missing"
Cant write/apply a new added keyword. Will get the same error-window...
Sorry for that...
Issue reopened
This problem is supposed to be fixed in XnView MP 1.6.4. Please check and confirm the bug fix here.
Gerald_Ire
Happy New Year! Yes, I can confirm: It's solved!
Info (how to): type your keyword into xmp "subject" metadata field and (please) hit "enter/return" on keyboard...
