[SOLVED] 1.5.4: Hangs on Startup
Stuhrer
Post by Stuhrer »
XnView: MP 1.5.4 - 64 bit
OS: Mac OS 13.5.1 (22G90)
XnView MP hangs on startup after installation of the new version. It is unusable on my Mac. I installed the 1.5.3 version again. That works.
Re: 1.5.4: Hangs on Startup
Do you start it in browser mode?
Stuhrer
Post by Stuhrer »
xnview wrote: Thu Sep 07, 2023 9:22 am Do you start it in browser mode?
I removed the directory of the settings (<user>/.config/xnviewmp) and started the app using the default settings. Then a window appears which allows defining the place of the ini-File and other settings. I left this untouched and continued. Thereafter, the app freezes immediately.
Stuhrer wrote: Thu Sep 07, 2023 12:16 pm I removed the directory of the settings (<user>/.config/xnviewmp) and started the app using the default settings. Then a window appears which allows defining the place of the ini-File and other settings. I left this untouched and continued. Thereafter, the app freezes immediately.
Do you have TIFF in your home folder or subfolder?
Stuhrer
Post by Stuhrer »
xnview wrote: Thu Sep 07, 2023 1:31 pm Do you have TIFF in your home folder or subfolder?
No, there are only directories in my home folder. The previous version runs without problems. What do you mean with subfolder? There are of course TIFF-files in some subfolders of my home folder. XnViewMP should be able to handle them.
There i an issue with TIFF files, i release a 1.5.5 today
Stuhrer
Post by Stuhrer »
xnview wrote: Fri Sep 08, 2023 5:50 am There i an issue with TIFF files, i release a 1.5.5 today
OK, great! I shall try the update as soon as possible and let you know whether this solved the problem. Until then, I can work with 1.5.3.
By the way, thank you for the great job. I love XnViewMP. It is the center app of my photo management and processing.
Greetings from Bremen in Germany
Bernd
Stuhrer
Post by Stuhrer »
I just installed version 1.5.5 and the problem is solved. Excellent work. Thank you very much and have a good weekend.
Bernd
