1.5.4 Barely any video thumbnails
philalethia
Banned
Post by philalethia »
Now I've always encountered the rare occasional video file, that doesn't get a thumbnail, for some inexplicable reason
..but after the upgrade to 1.5.4, almost no video, gets a thumbnail!
At first, I thought that none of them did, but when I checked a folder with only videos, I noticed a few had thumbnails.
This is on my Windows 7 computer. My other computer, running Linux, seemed to show thumbnails, just as before
...but then I checked "About", and notice that it says it's still version 1.5.2.
Even after I upgraded.
So https://download.xnview.com/XnViewMP-linux-x64.deb, is apparently version 1.5.2...
Edit: So, of course, what I've written in Quick Search within categories, right before this post, also only applies to the Windows computer.
Re: 1.5.4 Barely any video thumbnails
philalethia wrote: Thu Sep 07, 2023 12:05 am Now I've always encountered the rare occasional video file, that doesn't get a thumbnail, for some inexplicable reason
Could you post a sample file?
are you sure that you have updated?? It's the 1.5.4
philalethia
Banned
xnview wrote: Thu Sep 07, 2023 8:38 am Could you post a sample file?
Why?
The files that get a thumbnail, are the exception, so...
I can assure you, that I installed the file, https://download.xnview.com/XnViewMP-linux-x64.deb ...and it is 1.5.2
philalethia
Banned
I'll post a relatively small video, among the countless ones, that don't get a thumbnail.
FRoYhbEXoAE7h-l.mp4
(11.9 KiB) Downloaded 125 times
philalethia wrote: Thu Sep 07, 2023 8:47 am I'll post a relatively small video, among the countless ones, that don't get a thumbnail.
it works here on win 10, do you have 'show as thumbnail' for video in 'Settings>Filelist>Custom filter'?
i've tried to install the .deb and its 1.5.4
philalethia
Banned
xnview wrote: Thu Sep 07, 2023 9:40 amit works here on win 10, do you have 'show as thumbnail' for video in 'Settings>Filelist>Custom filter'?
Of course. Why else would I have had thumbnails, before?
I double-checked, but... I really didn't need to.
Also, surely that only applies, when using the custom filter, and not when you choose "filter by" video? ...and I've used both, with the same results, in terms of video thumbnails.
i've tried to install the .deb and its 1.5.2
philalethia wrote: Thu Sep 07, 2023 10:31 am Of course. Why else would I have had thumbnails, before?
You had them with 1.5.3?
what file size do you have for the .deb?
philalethia
Banned
xnview wrote: Thu Sep 07, 2023 2:25 pmYou had them with 1.5.3?
I said I had them, in all previously installed versions, in the initial post.
Why wouldn't I?
(though, strictly speaking, I never used/installed 1.5.3, but went from 1.5.2, to 1.5.4, so no. I didn't have them in 1.5.3, as I never used it)
I also have them, in the Linux computer, obviously.
I didn't save it, but re-downloading it... it is 48 246 406 B (I can't be sure, that it's still the same file, as when I installed it)
philalethia wrote: Thu Sep 07, 2023 2:46 pm I said I had them, in all previously installed versions, in the initial post.
Why wouldn't I?
Could you try to replace mdk.dll from 1.5.2 or 1.5.3 to 1.5.4 folder?
it's the 1.5.4 package
philalethia
Banned
xnview wrote: Thu Sep 07, 2023 2:54 pmCould you try to replace mdk.dll from 1.5.2 or 1.5.3 to 1.5.4 folder?
And where would I get it from?
Then you must have updated it, since I installed it.
Edit: I checked the zip-download of XnViewMP, and copied the mdk.dll from there (renaming the mdk.dll that is present, into mdk.dll.bak) ...which resulted in XnViewMP, not running, but instead getting an error message. Removing it, and re-renaming the original file, fixed that.
I'm tempted to simply install 1.5.2, to "upgrade" from 1.5.4 to 1.5.2.
PVDSL
Post by PVDSL »
bonjour,
j'ai le meme problème depuis la dernière mise a jour.
plus de création de vignettes sur les fichiers vidéo alor que ça fonctionnait sur les versions precedentes.
un utilisateur des premiers instants.
No, perhaps a cache problem...
Please use this file
mdk.zip
(789.51 KiB) Downloaded 91 times
PVDSL wrote: Thu Sep 07, 2023 8:16 pm j'ai le meme problème depuis la dernière mise a jour.
Windows 10?
PVDSL
Post by PVDSL »
yes
PVDSL
Post by PVDSL »
Good morning,
after replacing the mdk.dll it works very well.
THANKS
