In Batch Rename, numeric enumerator with Leading zeros would be great. So that it would automatically add the leading zeros depending on the amount of files in current Batch Rename session.
Example: If you have more that hundred and less than thousand files in Batch Rename, the Leading zeros would go like this. 000, 001... 010, 011... 100, 101
REQ: Leading zeros for Batch Rename
Oh thanks man. Thats exactly what I am looking for.FlorianH wrote:Did you try to use '###_name.jpg' as template? Then you get 001_name.jpg, 002_name.jpg, 003_name.jpg, ...
I think that's what you are looking for. Or did I get you wrong?
This topic can be closed.
