1.5.2 - viewer - crash - during HEIC fast scroll
XnViewMP 1.5.2 64bit
Viewer - crash
2. have 4 HEIC images in folder, open any of them
3. fast scroll back and forth ~10-20 times
(optional) it may require to resize app window (to 50-70% screen space) as it does not crash when small or maximized
app will crash
Re: 1.5.2 - viewer - crash - during HEIC fast scroll
and you can't reproduce with 1.4.5?
right, no crash on 1.4.5
Could you try 1.5.2 with heic.dll from 1.5.0?
you mean ../plugins/heif.dll ?
no issue in 1.5.2 with dll from 1.5.0
user0 wrote: Mon Jul 24, 2023 3:56 pm you mean ../plugins/heif.dll ?
yes
It's the same dll, or you means 1.4.5?
I used unzipped app archive 1.5.2 x64 with:
- heif.dll 1.5.2 (575kb, same dll as in 1.5.1) - crash
- heif.dll 1.5.0 (491kb, same dll as in 1.4.5) - no crash
This problem is supposed to be fixed in XnView MP 1.5.3. Please check and confirm the bug fix here.
no issue in 1.5.3
foxyshadis
Post by foxyshadis »
Did you guys do any kind of triage or get crash logs on this? I might be able to track it down and fix it if I can see what might've happened. The odd thing is that 1.16 hasn't really introduced changes in the threading behavior, so I'm curious why one works and the other didn't.
foxyshadis wrote: Sat Sep 02, 2023 12:39 pm Did you guys do any kind of triage or get crash logs on this? I might be able to track it down and fix it if I can see what might've happened. The odd thing is that 1.16 hasn't really introduced changes in the threading behavior, so I'm curious why one works and the other didn't.
I don't understand why we have crashs with 1.16.2
foxyshadis
I guess I'll try to see if there's any way to reproduce it, then, and check in a libheif fix if it's a new bug.
