no colour information with dark theme
Subject: 1.4.3: no colour information with dark theme
XnView: MP 0.99.7 - 32 bit/64 bit
OS: Linux Mint 21 64bit
In dark theme and black theme there is no colour information if you activated it in View | Show colour information (Ctrl+Shift+I), default and light theme are OK
Effect: Only an empty white rectangle is shown with no information in it
1. open any picture
2. enable „show colour information“ (Ctrl+Shift*I)
3. point anywhere in the picture
Actual behaviour (bug): shows only a white rectangle
Expected behaviour: show position and colour information
1. open any picture
Not only for cars: "Add lightness -- Colin Chapman, Founder of Lotus"
Re: no colour information with dark theme
Yes I confirm this with Linux Mint.
On the other hand for the theme "Old Dark" on Linux and Windows the text is too clear and is not visible enough.
i can't reproduce, what do you have in Settings>View>Info?
I have that, but this is the information of the image not that of the colors.
Voilà le fichier demandé.
Cordialement
Cordialement
- Attachments
- xnview.ini.tar.gz
- (5.42 KiB) Downloaded 88 times
Si tu pouvais en même temps assombrir le texte dans le thème "old dark" qui est trop clair.
Merci Pierre Re: no colour information with dark theme
il est possible de modifier le style_sheet.qss, en rajoutant
MyTooltip {
color: black;
Oui mais lors d'une mise à jour cette modification reste ?
J'ai fais la modif, et c'est bien mieux comme ça.
Merci Re: no colour information with dark theme
The problem is solved with this V1.4.4.
Thanks
Thanks
