Problems using the "Delete original" option and one wish
Gido
Post by Gido »
1. After the conversion of each file, it is deleted, but at the same time the current program window (any program) loses the focus for a split second. This leads to while XnConvert works is actually impossible to use the computer.
2. I'm not sure how it is now, but at least a year ago, even if the converting fails, the original file was still deleted. Agree that this is a very unpleasant situation.
3. After completing the process, I would like to see a separate log where there will be a list of files that caused errors. Now it is quite difficult to look for them in a huge general list.
Re: Problems using the "Delete original" option and one wish
Gido wrote: Thu Mar 09, 2023 12:21 pm 1. After the conversion of each file, it is deleted, but at the same time the current program window (any program) loses the focus for a split second. This leads to while NConvert works is actually impossible to use the computer.
Windows?
You need to try latest version...
Ok, perhaps at the end...
Gido
Post by Gido »
Yes, Win10.
Gido wrote: Wed Mar 15, 2023 9:03 amYes, Win10.
If you don't use 'recycle bin', no more problem?
Gido
Post by Gido »
I'm not sure that I understood your question. Please paraphrase and specify.
P.S. Someone on this forum secretly changes the text of the messages, I see it the second time. Initially, I talked about the XNconvert program, but someone changed the text to "Nconvert". And besides, I never used Nconvert.
in xnconvert.ini, could you try to change
useRecycleBin=false
