Duplicate top menu items
esv
Post by esv »
After I close some all tabs (and maybe in some other cases I haven't noticed) I get duplicate menus (e.g., View menu is duplicated in the screenshot below), so I have to restart the app to get the regular menus back.
It seems like somehow they can't get merged properly on some changes, so instead of creating a proper sub-menu, a new menu item is created with the same name that contains only this sub-menu
XnView: MP 1.3.1 64 bit
OS: macOS 10.15.7 64bit
(though same thing happens on a Windows 10)
View menu 2
View menu 2
View menu 1
View menu 1
Re: Duplicate top menu items
are you able to reproduce?
esv
Post by esv »
Yes, always, here is the simplest list of steps I've found that reproduces this bug:
- Close all tabs
- Close XnViewMP
- Open an image (opens XnViewMP with a single image tab)
- Hit Enter to open the browser tab
- Close the browser tab and the image tab
- Observe multiplying menus
Repeat the last 4 steps and you get
ok i can reproduce if 'Settings>Interface>Tabs - Closing last tab' is not checked
esv
Post by esv »
Ok, good that you can repro it.
That option is useful to me as it help easily open various photos from various folders from the file manager (so, to use XnView as "just" a viewer) and then just hold ⌘W to close all the clutter without closing the app and then suffering the startup delay when viewing another photo
esv
Post by esv »
Can confirm it's fixed and not creating any duplicate menus (I see the menu flashing when I close the last file, which I assume is that "refresh" action the prevents duplication)
Thank you!
