Re-saving PNG deletes EXIF
esv
Post by esv »
In Setting→General→Formats→Write I have all 4 metadata checkmarks ticked/enabled (as far as I understand, this is a common section for all formats, so should also work for PNG)
  • Keep EXIF
  • Keep IPTC
  • Keep XMP
  • Keep ICC profile
However, when I resave a scanned PNG file (via export or cropping and saving or saving as), the EXIF section of the file is gone
XnView: MP 1.3.1 64 bit
OS: macOS 10.15.7 64bit (though same thing happens on Windows 10)
Re: Re-saving PNG deletes EXIF
EXIF is not supported by PNG
esv
Post by esv »
Well, it is supported by the PNG:
yes right, i didn't know that a special chunk was added. Could you send me a PNG file with EXIF data?
esv
Post by esv »
Sure thing, the attached file is a tiny screenshot of a white screen area, it does show IFD0 and Exif IFD fields
PNG with EXIF
PNG with EXIF
esv
Post by esv »
Upd: I've learned that the Apple chunk is supposed to disappear per PNG spec, but that still doesn't explain the warning
Just converted a screenshot in the new version and noticed that there is a warning from exiftool, though not sure what it is
before
Apple Data Offsets              : (Binary data 28 bytes, use -b option to extract)
after
No field 'Apple Data Offsets' (as it should be)
Warning                         : [minor] Text/EXIF chunk(s) found after PNG IDAT (may be ignored by some readers)
could you send me the file?
esv
Post by esv »
Sure
xn1.png is the original screenshot
xn2_edit.png is the same file cropped in XnViewMP with the warning
it's only a warning, LIBPNG writes at the end the EXIF chunk...
