b2: problem with loading images in separate thread
Locked
Xyzzy
Post by Xyzzy »
See here:
http://newsgroup.xnview.com/viewtopic.php?t=4422
I confirm.
b2, delete ini.
Go to directory with many big images. Select image & press F11.
Now quickly press PgDown multiple times. Image loading is not interrupted and it should.
Also, after stopping pressing PgDown you can see keypresses still processed by XnView (a few next images are displayed).
X.
Re: b2: problem with loading images in separate thread
Xyzzy wrote:See here:
I confirm.
b2, delete ini.
If you disabled "High quality', do you have always the problem?
With or without 'Read ahead'?
Xyzzy
Post by Xyzzy »
Which 'High quality' do you mean?
X.
Olivier_G
Post by Olivier_G »
OK... I believe I was able to get "something" (and setting View>'High zoom quality' or 'Cache Read Ahead' didn't change anything...).
In Fullscreen, if you keep pressing PgDown on large images, you will actually skip the image AFTER the one being loaded... (the one being loaded will be fully loaded and displayed).
So: XnView is loading 1. You press 'next' => XnView continues to load 1 and will display 1, but will skip 2. It will then directly load and display 3.
This is not what I expected... :(
I hoped for the possibility to interrupt the current loading of image:
XnView is loading 1. You press 'next' => XnView immediately stops loading 1 and display what has been loaded so far of 1, before proceeding to 2.
Would this last behaviour be possible, Pierre?
Olivier
Olivier_G wrote:OK... I believe I was able to get "something" (and setting View>'High zoom quality' or 'Cache Read Ahead' didn't change anything...).
Do you have tested in beta 3? Loading is interupted!
Xyzzy
Post by Xyzzy »
Well, I have tested now and I have mixed feelings.
I tested with 2-2.5MB JPEGs. If I press PageDown ten times in about 3 seconds, after last press there are still approx. 2 image skips to next picture.
I wonder if it may be caused by the way Windows processes keypress messages when under load (images are rendered), delivering them to application with some delay???
X.
Xyzzy wrote:Well, I have tested now and I have mixed feelings.
Yes i think, i'll try to fix it
Xyzzy
Post by Xyzzy »
OK, I have checked with some other image browser and it seems it is "how things work". It can be improved, but rather not quite eliminated. If improvements are made, OK. If not, current behaviuor is acceptable as well.
Close.
X.
Locked
