Hi Pierre!
Can you add feature to search and recognize Barcode and QR code?
The result can be written to EXIF or used to rename the file.
Recognition can also be placed in batch processing.
And a related task: generating different barcodes, in addition to QR.
For example, here is a library that can work with barcode:
https://github.com/zxing/zxing#zxing-ba ... e-projects.
Thanks!
Barcode and QR code recognition and generation
