b2: slide show: turn around
Locked
thire-logged off
Post by thire-logged off »
Imges with a EXIF orientation tags are not right adjusted in slide shows.
th
Re: slide show: turn around
thire-logged off wrote:Imges with a EXIF orientation tags are not right adjusted in slide shows.
I confirm
Xyzzy
Post by Xyzzy »
Verified fixed. Reproduced bug in Beta 2, in RC1 this works, o.k..
Moved to "Closed/Solved".
Locked
