1.0 beta #4 - Copy to inside archive is not working
mpy
Post by mpy »
In ZIP archives using the "Copy to..." function results in an error "Source not found", although the function in the context menu is enabled (in contrast to "Move to..." for example which is disabled), but not working as expected.
1. Open an arbitrary zip file with images in XnViewMP
2. Right-click on an arbitrary thumbnail
3. Select "Copy to..." and specify path where you have write access to.
4. Click "Copy".
Expected behavior: File is extracted from the archive and copied to the specified location.
Actual behavior: Error dialog says that "Source doesn't exist."
Linux/Arch
XnView MP Linux
Version 1.0 64bits (Apr 25 2022)
Libformat version 7.110
Re: 1.0 beta #4 - Copy to inside archive is not working
I've just tried on Windows 10 and similar problem occurs: Message "Copy warning" saying "Source doesn't exist" is displayed. Displayed Source is "Numbers/A/102.png" (browsed ZIP archive is "D:\User\Helmut\Downloads\Numbers.zip").
for this version, i disable the 'copy/move to' from archive
