0.99.1 64-bit: When viewing videos, a black screen shows up after loops ends.
ninja
Post by ninja »
XnView: MP 0.99.1 - 64-bit: When viewing videos, a black frame shows up after loops ends.
OS: Windows 10 - 64-bit
Effect: black frame shows up after video loops ends
When viewing videos, a black frame shows up after loops ends. This makes it impossible to check if the video loops correctly.
1. Make sure in Settings, View, Misc., that the Loop video playing is enabled.
2. Browse a folder any of video format. (mp3, webm, avi)
3. Select the video
4. View the video. Also look at the preview video as well.
Actual behavior (bug): At the end of the video, there is a black screen that shows up for a second before the video loops from the beginning again.
Expected behavior: The video loops seamlessly from the start. Just like every other viewer.
Re: 0.99.1 - XnView MP 64-bit: When viewing videos, a black screen shows up after loops ends.
yes, you can have a black frame, video is restarted once finished
ninja
Post by ninja »
What I meant is that it shouldn't have the black frame. If you compare this image viewer with other players and even players on websites, there is no black frame in between as the video loops back.
https://i.imgur.com/b59kZN4.mp4
Painless
Post by Painless »
xnview wrote: Tue Nov 23, 2021 12:59 pm yes, you can have a black frame, video is restarted once finished
Can you please elaborate? This bug happens with all videos.
Bug/behaviour confirmed :bugconfirmed: with XnView MP 0.99.7 using a WMV video: A black screen is displayed once the video is over. Instead of a black screen the user wants that last frame is displayed. I've just played the same WMF video using Windows 10 built in Video player and there last frame is displayed once video is over.
