How to resize and keep the aspect ratio?
ARCH_ANGEL
Post by ARCH_ANGEL »
Hello
If i change rectangular image to square, the shirt in the picture will stretch and look ugly
I want to change rectangular image to square but still keep the aspect ratio? (rectangular). So is there any function that fills the space with white colour. So the shirt in the picture still retains the standard size, but the image is converted to a square
Re: How to resize and keep the aspect ratio?
You might look at the Canvas resize action if you haven't already done so...
I haven't had time to read your post closely, though, as I'm just going out.
ARCH_ANGEL
I've done it already. thanks a lot.
ARCH_ANGEL wrote: Mon Aug 16, 2021 4:15 pm I've done it already. thanks a lot.
Is your problem solved or do you possibly need further support?
