Hi to all!
I'd like to avoid to install GosthScript as a viewer or pdf editor and would love the option when choosing a programm for a file attribute that this would open it - on the fly - when clicking on icon in the XnViewMP browser - instead of right click - choosing program - open file with...
Any chance to do so as a permanent way?
Open image with... (exp Pdf with Acrobat Reader) as a permanent choice...
- Gerald_Ire
Gerald says thx to all!
Re: Open image with... (exp Pdf with Acrobat Reader) as a permanent choice...
i have no way to use Adobe Reader to load pdf file
- Gerald_Ire
Ok! Thx Pierre! So I will explain this in our XnViewMP manual how this in done in the XnViewMP GUI. Thx for reply
- Gerald_Ire
Hi! Found the "solution"... or I do now understand the option "F3"
If "pdf" is setup in windows to "Acrobat Reader" we can open the pdf with shortcut "F3" ...
I feel it would be a huge win if XnView could be programmed to open pdf's with the default pdf-viewer.
So instead of hitting F3, just a regular double click or "enter" that opens the pdf.
Would be more user friendly!
(I already have countless shortcuts I have to remember for each individual program, lol...)
change AI/PS/PDF to Associated program in Settings > File list > Custom filterVolbloed86 wrote: Tue Jan 21, 2025 8:14 pm XnView could be programmed to open pdf's with the default pdf-viewer..
Thanks for getting back to me.
I think (?) I have that setting enabled (see below), but XnView still just shows my pdf's like an image if I double click on them.
My default pdf-viewer is Acrobat.
Is there some other place where I have to tell XnView to use Acrobat?
This is just a checkmark...
Custom filter, not Filter
Fabulous! Thanks a bunch!!!
@Developer: I missed this because if you search through the settings for "pdf", for some reason this setting page doesn't show up...
Can this be remediated?
- Attachments
- Schermafbeelding 2025-01-27 060533.png (5.59 KiB) Viewed 1689 times
