Add Text via filename character position
digiformer
Post by digiformer »
I would like to add parts of the file names with batch editing.
Preferably with indication of the character position. For example, <filename {characters 6 to 20}>.
Is this possible? Possibly via a custom script?
I have not found anything in Xnview. The search here in the forum did not yield any results either.
Thank you for helping,
Kind regards
Tobias
Re: Add Text via filename character position
yes you can use
<Filename [6-20]>
