I can not stop XnView using second monitor for preview or whatsoever.
[Full]
BackColor=0
DualMStretch=0
DualMUse=1>>>>>>>> this value can not be turned to 0 it means this can not be changed to one monitor at all...
Fit=2
HidePlayBar=1
HideScrollBar=0
LockZoom=0
SizeDelay=1024
UseDelay=1
Config went wrong.
Config went wrong.
Re: Config went wrong.
This is again wrong Multilayer Design in area of UI...
The dual monitor config in mentioned by me section is not recording its desired value at all,
and there is another "Dual Monitor" setup in the other section.
I am Multilayer Designer for big Data and this kind of mistaken layout is kind of bad, very bad example of inside
your program relations.
Lost plenty of time and found it.
But the Full Screen config is still not adjustable.
So why it is there in the first place.
Pierre:
seems your lapidary answer is proof that you tired with typing anything, the first bad habit for developers of any Digital Designs and coding.
On basis of your answer nobody can find the way to "do it", and "you need to disable 'Use second monitor" is explaining nothing to the topic except repeating the subject of this conversation and support request.
