GPS tab gone ???
rmtk
GPS tab gone ???
Post by rmtk »
In 0.98.3 I can no longer see the GPS tab with google maps. Is it removed or just a bug?
Re: GPS tab gone ???
Please click 2 times on View>Info pane>Preview as tab
rmtk
Post by rmtk »
Ok, I can get back the GPS tab this way. But when I selected a geo-tagged picture and deleted it, the GPS tab disappered again.
rmtk wrote: Mon May 31, 2021 2:16 pm Ok, I can get back the GPS tab this way. But when I selected a geo-tagged picture and deleted it, the GPS tab disappered again.
?? if you re select a file with GPS data after?
rmtk
Post by rmtk »
I can't see the GPS tab until I do the Info pane>Preview trick again.
and if you select a geo tagged file, no GPS tab?
rmtk
Post by rmtk »
No. Everytime after I delete a file in browser, I have to select and deselect preview as tab to get the GPS tab back.
rmtk wrote: Wed Jun 02, 2021 4:32 am No. Everytime after I delete a file in browser, I have to select and deselect preview as tab to get the GPS tab back.
I can't reproduce, could you send me a screenshot of layout used?
rmtk
Post by rmtk »
'Preview' is hidden?
rmtk
Post by rmtk »
Yes. does it trigger the problem?
:bugconfirmed: Thanks to your detailed description I can reproduce if the preview is disabled the problem.
This problem is supposed to be fixed in XnView MP 0.99.0. Please check and confirm the bug fix here.
