Request for a new parameter to the -canvas command.
SAMSAM
Post by SAMSAM »
Good afternoon!
I want to make a request to add the parameters "on the long side" ("on the short side") to the -canvas command, as it is done in the -resize longest size (-resize shortest size) command. This parameter allows you to change the size (canvas) of multi-page tif files, regardless of the orientation of the pages inside it.
Re: Request for a new parameter to the -canvas command.
will be added
SAMSAM
Post by SAMSAM »
I tried a new command with the parameter (-canvas longest 220mm center) The original size canvas of 142x214mm changed incorrectly to 12x10 mm. Tell me what I'm doing wrong.
Result file
Source file
ok right, will be fixed
SAMSAM
Post by SAMSAM »
I tried in version 7.95 everything works as it should. Thank you, a very useful team for my work. :D
