Scaling Problems (Aliasing, Poor Quality, Not 1:1)
oakside
Post by oakside »
Problem:
Images should be showing unscaled (1:1), but are instead showing scaled (downscaled, to about 99%). Scaler has problem or poor quality.
Notes:
Very noticeably degrades quality, especially with text and lines, producing much aliasing. Pressing key shortcut (asterisk) to go to 1:1 scale will bring to proper scale for most images (quality improves immediately), but not for all (see "Spek.png", strange, still aliased text and poor quality). Compared with other image viewers, they do not exhibit problem.
I've tried various HiDPI and scaling settings in XnView (high zoom quality never, lanczos, bicubic, zoom on hidpi, etc). Also forcing alternate DPI settings (via XnViewMP.exe, Properties, Compatibility, Change High DPI, Override, Application). Also tried modifying "Auto Image Size" (problem definitely occurs with "Fit Image to Window, Large Only"). Will try to hunt down the cause more if not related to bug that is already reported and fixed. Thanks for any help with this.
Examples:
Screen 1 (auto fit, 99% scale), Screen 2 (100% scale, manually set 1:1 with "asterisk")
All (Video, Screens, Samples) (MEGA, rar) (video shows once through with auto-fit 99%, then pressing "asterisk" for 100%, then "plus" for 110%)
Specs:
XnView MP 0.98.2 x64 (zip, portable mode)
Windows 10 Pro (20H2, build 19042)
Monitor: Philips 27" UHD (2560x1440, 125% scale)
Re: Scaling Problems (Aliasing, Poor Quality, Not 1:1)
I can't reproduce on HiDPI screen with scaling of 125%, do you have same problem with 'High zoom quality' => 'Zoom in&Zoom out' + bilinear?
The problem is only viewing at 99%?
And if you use 100% for font scaling?
Do you have same problem with 0.98.1?
oakside
Post by oakside »
xnview wrote: Mon Apr 12, 2021 1:15 pm I can't reproduce on HiDPI screen with scaling of 125%, do you have same problem with 'High zoom quality' => 'Zoom in&Zoom out' + bilinear?
Thanks for taking a look at this, Pierre. And for all your work on the fantastic XnView.
1. Bilinear looks much better (high quality, in/out), just a bit soft, but no aliasing. (I tried many combos, maybe I missed that one, apologies!)
Will use that for now. All the others are downscaling poorly for some reason? (I usually use Lanczos with most apps, XnView batch convert.)
So perhaps this is actually two problems?
2. Images displaying at 99.?% scale, when "Auto Image Size" set (Fit to Window, Large Only). If switched to "No Fit", images display fine (at 100% scale, scaling now properly off). Will disable that for now. Note: Any downscaling still poor quality (if not using bilinear).
Hopefully the source of these problems can be found, and next XnView version I can use sharper scaling (lanczos/spline), plus enable "Auto Image Size again.
Update: Same problems with 0.98.1, no problems with 0.98. Related: Maybe this or this (both over at "Retest"). Note: I've been using XnView MP for years, maybe time for a settings reset (but that won't be fun, only if necessary).
oakside wrote: Mon Apr 12, 2021 5:25 pm 1. Bilinear looks much better (high quality, in/out), just a bit soft, but no aliasing. (I tried many combos, maybe I missed that one, apologies!)
oakside
Post by oakside »
xnview wrote: Wed Apr 14, 2021 2:30 pm :bugconfirmed: Thanks to your detailed description I can reproduce the problem.
That's just amazing. Bugs squashed (or collected and put outside). Thank you for caring! Can't wait for 0.98.3.
This problem is supposed to be fixed in XnView MP 0.98.3. Please check and confirm the bug fix here.
oakside
Post by oakside »
Thank you for 0.98.3!
The good news is the scaling quality is much better. Used my test images to verify. :D
The bad news is images are still very slightly scaled (99.x%) for some reason, as described before. Just higher quality and less noticeable since scaling is now much improved. Verified by using my test images, pressing "asterisk" to go to 100%, which clearly shows change in image. when they should be untouched. Notes: Same behavior as described before, and in my test video. Same settings: Auto Image Size, Fit to Window, Large Only. Test images are much smaller res than window, should display perfectly 1:1 unscaled. :?
Edit: Maybe related, noticed my test images (except spek.png) seem like they are being slightly cropped when this occurs, maybe due to resolution (tiny, and not even mod2). I will need to test a lot more over the next few weeks to see just how many images are affected, but does not look like many right now.
oakside wrote: Thu May 06, 2021 9:21 pm The bad news is images are still very slightly scaled (99.x%) for some reason, as described before. Just higher quality and less noticeable since scaling is now much improved. Verified by using my test images, pressing "asterisk" to go to 100%, which clearly shows change in image. when they should be untouched. Notes: Same behavior as described before, and in my test video. Same settings: Auto Image Size, Fit to Window, Large Only. Test images are much smaller res than window, should display perfectly 1:1 unscaled. :?
This problem is supposed to be fixed in XnView MP 0.98.4. Please check and confirm the bug fix here.
oakside
Post by oakside »
Thanks again Pierre for your work on this fantastic software. Does not show 99% anymore (auto image size), nor does image change in any way after pressing asterisk (go to 100%). Everything seems fixed here. Quality is superb again. :D
tuwulin365
Post by tuwulin365 »
xnview wrote: Tue Jun 01, 2021 12:33 pm This problem is supposed to be fixed in XnView MP 0.98.4. Please check and confirm the bug fix here.
The bad news is images are still very slightly scaled (99.x%). see display1.png.
Specs:
XnView MP 0.99.4 x64
Monitor: 3840x2160, 150% scale
sample
sample
ok,display2
ok,display2
bad,display1
bad,display1
