Get "EXIF:DateTaken" with NConvert
Peter2
Post by Peter2 »
I try to use NConvert inside a AHK (AutoHotKey) Script, and there I want to extract and save and reuse the value of "EXIF:DateTaken". Is this possible?
Re: Get "EXIF:DateTaken" with NConvert
you would like to extract EXIF:DateTaken value to use it in your script, right?
Peter2
Post by Peter2 »
xnview wrote: Wed Jan 13, 2021 6:59 pm you would like to extract EXIF:DateTaken value to use it in your script, right?
Correct.
Perhaps extract the info with
Peter2
Post by Peter2 »
Oops - my bad. I tried only "-info" ... :(
Thanks
