XnConvert use same settings from XnViewMP ?
masterjp
Post by masterjp »
Most of the time I use XnViewMP and XnConvert with the same settings.
Today I wanted to use different settings and changed the jpeg/webp compression.
I was suprised that XnConvert use the same settings than XnViewMP.
Is it possible and correct?
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
Re: XnConvert use same settings from XnViewMP ?
no, XnConvert use xnconvert.ini
