Wrong path when saving via "Save as..."
misao
Post by misao »
When saving an image via "Save selection..." the path is set to the directory of that image, however, when saving via "Save as..." it only does this once and doesn't update the path when saving images from other directories.
Re: Wrong path when saving via "Save as..."
"Settings>General>File operations - For save as use original..." is enabled?
misao
Post by misao »
xnview wrote: Thu Oct 29, 2020 2:17 pm "Settings>General>File operations - For save as use original..." is enabled?
No :shock:
Thank you!
